CBR F2 1994 Radiator
Does anyone know if it is easy to change the radiator to something smaller maybe chrome rad from a different bike? Are there any specs to radiators if so, that I would need to look out for to make sure it is compatible?
Any links or make of motorcycle the F2 could use, would be appreciated.
If its too much smaller it might not keep the temp in check. Most people want bigger radiators if they wanted to change it in the first place. I'm not sure what your plans are but check out radiators on ebay and compare......mounting points, inlet and outlet locations, etc. Nothing would be a direct bolt on. Its definitely going to require some custom fabrication on your part.
As you can tell the front looks a little wierd with such a wide rad!
This is my F2 now. Still a lot more i need to do to it, looking at f4i rear tail and vfr 750 single swing arm conversions.
