CBR 600 F2 carb sync
Old May 14, 2022 | 04:25 AM
Limpan's Avatar
Default CBR 600 F2 carb sync
Hi!
I have just bought a "Carbtune Pro" device to have the carburetors synchronized on my 1994 CBR 600.
I'm a little confused about the locations where to attach the 4 vacuum hoses from the tool correctly.
Any help/picture will be appreciated.
Thanks in advance!
Regards,
Thomas
Old May 14, 2022 | 06:54 AM
Phil314's Avatar
There are vaccum ports below each of the 4 carbs, in the side of the intake port.
Some may just have screws in them, remove the screws and thread in the adapters you should have gotten with your device.
Others will just have rubber caps over the vaccum port. #1 cylinder will be like this since it feeds the petcock.
You might want to T that one or use a separate gas source.
Old May 14, 2022 | 09:20 AM
Limpan's Avatar
Thanks a lot for your reply, it will make it easier for me to go thru the job!
(I have an external gas tank so I can skip the T-connection.)
Once again, thank you very much for your help!
Thomas
Old Jul 6, 2022 | 10:38 AM
Rellksnald's Avatar
Most important check before all the hard work, hook all 4 inputs together to check the carbtune measures the same on all four scales from one source.
Tutuapp 9Apps Showbox
Old Jul 11, 2022 | 03:48 PM
Limpan's Avatar
Thanks for the tip!
redhurricane
Jul 12, 2011 04:45 PM
Seadoomanls
Apr 29, 2011 12:10 PM
Chaxx
Aug 19, 2010 07:26 AM
antatious
Jul 13, 2010 10:15 AM
LMP1327
Dec 25, 2009 10:42 PM
