Carb leak
Old Mar 11, 2012 | 06:16 PM
Atrom's Avatar
Default Carb leak
Got my bike out of storage today. Went to start it up and I noticed there was gas leaking from the carbs took the tank off and pulled the carbs removed the float bowls gaskets are still good replaced them last year. I reassembled it started her up and got the leak still. It seams to be a pretty decent leak not just a small leak. So I'm almost 100 percent sure it isnt coming from the float bowls so pretty much im puzzled on where its coming from.
Here's a pic of where the gas is coming from
My question is where is it coming from? any prone or possible pieces in the circled area?
Old Mar 11, 2012 | 08:05 PM
Atrom's Avatar
How likely is it to be the gasket on the joint where the fuel hose attaches to? The joint itself looks fine.
16040-MZ1-790
Old Mar 12, 2012 | 06:21 AM
underground-mpyre's Avatar
Check the seals, but start with the float needles. I am 90% sure if it isn't a small leak, it is the float needles. Replace all 4 all at the same time, they are are a easy fix. Find the carb cleaning thread and you will smack yourself how easy it is to replace them.
Old Mar 12, 2012 | 11:27 AM
JankCibberf2's Avatar
what is between the carb towers and the carbs itself, the screw on plastic plates? both my carb sets didn't have those... Im missing things!!!!
Old Mar 12, 2012 | 06:44 PM
Atrom's Avatar
I hope it's that easy. If the needles are bad they can cause a leak? Where would the gas be seeping out of? I pulled the bowls apart over the weekend and seals are still in good shape
Old Mar 12, 2012 | 07:17 PM
The needles are aluminum and mine were corroded. The get a tiny bit of corrosion and they will stick. You can try sanding the edges of the needles, but better to replace them. There is a spring at the end of them and do get worn out. Try this, if your floats are just resting on the top of the float bowls, good time to change them, they should be springy. I changed mine, got better mileage and better tone out of replacing the float needles. I am sure if your gaskets looked fine, I bet there is a tiny bit of corrosion on that bank of the float needles and causing them to stick. They stick and fuel goes backwards.
Old Mar 13, 2012 | 06:57 PM
Atrom's Avatar
Well I pulled the float bowls apart again today. I took a closer look at the needles and they seem to be clean with no corrosion.
The floats seem to be good yet, they definitely have spring left to them. Push them down they pop right up. So I guess I'm still stuck with the same question. What ELSE could potentiality be causing this?
Old Mar 24, 2012 | 08:47 PM
Atrom's Avatar
Well I ordered the joint gaskets last week I received them yesterday and replaced them today. Put it all back together and NO MORE LEAK!
Old Apr 4, 2012 | 08:36 PM
Atrom's Avatar
I replaced the o-rings on both of the t-joints on the fuel supply. I noticed after I got the new ones on that the joint was a lot stiffer. my old gaskets were definitely shot, they were completely flat.
NickLande
Aug 13, 2013 04:00 AM
DaniLee
Apr 21, 2012 02:33 AM
underground-mpyre
Apr 25, 2011 05:42 PM
F4Mike
Nov 22, 2010 09:06 PM
Ty_Deschaine
Jul 6, 2008 03:19 PM
