Carb leak
Got my bike out of storage today. Went to start it up and I noticed there was gas leaking from the carbs took the tank off and pulled the carbs removed the float bowls gaskets are still good replaced them last year. I reassembled it started her up and got the leak still. It seams to be a pretty decent leak not just a small leak. So I'm almost 100 percent sure it isnt coming from the float bowls so pretty much im puzzled on where its coming from.
Here's a pic of where the gas is coming from
My question is where is it coming from? any prone or possible pieces in the circled area?
Check the seals, but start with the float needles. I am 90% sure if it isn't a small leak, it is the float needles. Replace all 4 all at the same time, they are are a easy fix. Find the carb cleaning thread and you will smack yourself how easy it is to replace them.
The needles are aluminum and mine were corroded. The get a tiny bit of corrosion and they will stick. You can try sanding the edges of the needles, but better to replace them. There is a spring at the end of them and do get worn out. Try this, if your floats are just resting on the top of the float bowls, good time to change them, they should be springy. I changed mine, got better mileage and better tone out of replacing the float needles. I am sure if your gaskets looked fine, I bet there is a tiny bit of corrosion on that bank of the float needles and causing them to stick. They stick and fuel goes backwards.
Well I pulled the float bowls apart again today. I took a closer look at the needles and they seem to be clean with no corrosion.
The floats seem to be good yet, they definitely have spring left to them. Push them down they pop right up. So I guess I'm still stuck with the same question. What ELSE could potentiality be causing this?
Guest
Posts: n/a
Thanks,
I replaced the o-rings on both of the t-joints on the fuel supply. I noticed after I got the new ones on that the joint was a lot stiffer. my old gaskets were definitely shot, they were completely flat.
