Brake problems!!
Old Oct 25, 2008 | 10:50 AM
cnipp3173's Avatar
Default Brake problems!!
When i bought the bike the brakes would lock up so i took the calipers of and found a puck was stuck all the way in, so I had a newer pair that I put on with new brake pads. I bled all the air out and it holds pressure. I ride around the block using the front brake 4 or 5 times and it locks up, so i bleed it again no air came out just fluid. Where should i go from here?
Old Oct 25, 2008 | 12:39 PM
DRLOWZ's Avatar
Default RE: Brake problems!!
WD-40 the lever and make sure it is not stick and even a bit on the moving parts below....my rear was doing the same thing...little squirt and all fixed...
Old Oct 25, 2008 | 05:26 PM
cnipp3173's Avatar
Alright will try thanks.
Old Oct 25, 2008 | 07:18 PM
Hurricane rider's Avatar
how clean is your master cylinder? if its dirty, its entirely possible that your fluid return passage in the master is clogged, preventing the caliper from working right.
05CBR600F4i
Jun 1, 2011 04:26 AM
ccapitanu
Jun 30, 2009 01:41 AM
fastone4700
Jun 20, 2008 06:04 AM
JSTATL
Mar 11, 2007 03:16 PM
davrosxuk
Feb 24, 2007 07:03 PM
