head light went out, fuses are fine
RE: head light went out, fuses are fine
Check the socket to make sure you have voltage where it should be both with key in the on position and with the bike running.
The other things to look for is that the dimmer/horn switch is properly grounded as the ground is the same for the horn, front turn signals, and headlight according to the manual.
The circuit basically starts at the 10 amp fuse then heads through the engine stop/starter switch that controls the circuit. From there it looks like a wire heads to the horn/dimmer switch where it is either sent to the headlight as the high or low beam. The ground is as described above. Before the starter switch on the right handlebar the wire comes from the main 30 amp fuse.
The three wires coming from the headlight should be blue/white/green.
The wire going from the headlight switch over to the starter switch is blue with a white stripe.
The wire going from the 10amp fuse to the startr switch is a black and red wire.
This info is from the wiring diagram 19-1 in the service manual.
Like MikeInCtown said, check the wires coming into the starter button. The solder joints there have a tendency to break and the hot wire to the headlight comes through there. Try wiggling the starter button a little while the bike is running and see if you can get the headlight to flicker at all.
Same thinghappened to me this spring, I ended up replacing the entire wiring harness. Works now. May you have better luck in findingthe problemthan I. Wish I had known about those solder joints before, though.Fixeda solder jointproblemin my RX-7 a few years back, never gave it a thought it might apply in this case. Anyway, good luck.
