To bore or not to bore.
Old 08-06-2007, 12:44 AM
Mathis's Avatar
Default To bore or not to bore.
Tearing my engine down to change the trans in it, and since im ognna have it apart i was gonna go ahead and re-ring it, and new bearings if needed and was wondering if anyone out there has bored thier f2? Im having mixed opinions here on wether or not its worth it. Some say Ill notice a change in power other say I wont. Im only talking about like .10 or .25 over. Any opinions here.?
Old 08-06-2007, 11:44 AM
Default RE: To bore or not to bore.
buy a 900rr engine..........
Old 08-06-2007, 01:15 PM
whats it cost to bore it out ??
ask your self if its worth spending the money and effort for what kinda HP you `ll gain...
that is the question
Old 08-06-2007, 04:23 PM
Over-boring the cylinders will mean bigger pistons meaning more power. Bore, means the size of the cylinders and psitons.
Stroke means how far vertically, and how tall the cylinders are.
The more you have of both, the more power you have.
How much more?
That's something you'll have to ask about and calculate.
The thing you don't want to do is overbore too much. This will make the cylinder walls so thin, they'll be more easily warped and damged by heat.
If I were you, I would simply install a full exhaust system, and a carb kit upgrade, and do some work to the air-box, meaning a less restrictive filter.
Don't fit a 900 engine in the chassis. The chassis wasn't built for it, and unless you can find a cheap, and good engine, the cost is not worth it.
Old 08-06-2007, 05:48 PM
Mathis's Avatar
Too much work for a 900 engine. Was only thinking like I said .25 over MAXX.. boring is about 60 bucks a cylinder cause i know the guy at the machine shop. Then the pistons are 33 a piece and the rings will cost 116.00 Found uot today when I tok it al aprt I have a head gasket blown, with none of the usual signs except dark around the 4th cylinder ouside the engine. That might be the power loss I started having. I prob wil just rebuild with re-ring the thing and call it good. It has enough power.
JSTATL
07-19-2009 10:16 PM
twjtiger
07-19-2009 09:55 PM
JB50
11-12-2007 08:22 PM
mattstunt929
10-09-2007 08:04 PM
mikey1297
11-29-2006 02:38 PM
Quick Reply: To bore or not to bore.
