Best replacement clutch?
What do you guys consider to be the best replacement clutch, needs to be pretty bullet proof as I am a learner stuntor?
Also am I right in thinking the factory sprockets are 15/45?
Thanks again,
Dikko.
Thanks again,
Dikko.
Factory sprockets are 15/43. When you say "clutch" what are you talking about? The whole basket assembly or just the plates? If you're talking about the whole basket assembly, I would go with Barnett or something similar. Will cost you about $1k though. I think the factory setup should be strong enough to do some stunting, buy you might burn out the plates faster than normal riding. Maybe just get a good set of kevlar friction plates. I'm not a stunter so I don't know for sure.
