best replacement clutch kit?
Old 06-29-2014, 03:03 PM
Default best replacement clutch kit?
hey guys im gonna be replacing my clutch soon and just trying to get some views on what you all think is the best clutch kit to put in the f4i. mines an 03 f4i just so you know
Old 06-29-2014, 03:48 PM
Oem.
Old 06-30-2014, 12:28 AM
xtremef4i's Avatar
Originally Posted by boredandstroked View Post
Oem.
Agreed. Built to last
Old 06-30-2014, 09:56 AM
sounds good, what's a good place to buy the oem kit?
Old 06-30-2014, 10:14 AM
xtremef4i's Avatar
Dealership or any online oem retailer like Motorsport, Ron ayers, bike bandit etc.... Motorsport has 25% off oem right now but shop around to find best deal. Dealership will be the most expensive for sure. eBay May even have an oem kit too
Old 06-30-2014, 10:42 AM
kit including the steel and friction plates?
Old 06-30-2014, 10:49 AM
xtremef4i's Avatar
Yes. I would get all new steels and friction plates. May want to check to see if springs are still in spec or just get new while u have it all apart.
Old 06-30-2014, 10:57 AM
noob question but how many steel plates and how many friction plates, and also how do i check the springs?
Old 06-30-2014, 11:55 AM
xtremef4i's Avatar
http://www.motosport.com/motorcycle/oem-parts/HONDA/2003/CBR600F4I/CLUTCH-%28'01_'06%29
Check out this link for the parts and qtys needed. Note the diagram there are three different friction plates (1,6,1). And 7 steels all same. To measure the springs u need a digital caliper or some sort of measuring device to measure the length if the spring once you take them off. Wear limit of springs are 43.4 mm. As the spring wears it will lose its tension, or spring back. Most likely they will be in spec depending on mileage and how hard or soft you are on the clutch. If you are able to check them you can save some money or just buy all new if you are unsure. Also may want to make sure you readjust your clutch cable once you put the new clutch in. Word of advice before install: soak the friction plates in Bag of clean oil overnight before install and make sure steels are coated with oil too.
Old 06-30-2014, 01:18 PM
Agreed OEM is the way to go. Also, my springs were slightly out of spec so be sure to measure them as xtremef4i mentions. It's an easy job overall. Good luck.
Quick Reply: best replacement clutch kit?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
