battery problems
Old Sep 19, 2009 | 01:04 PM
pennstate12293's Avatar
Exclamation battery problems
i have a 93 cbr 600 f2 that i recently bought with only 4000 miles on it. it hasn't been running for about 2-3 years. i just got a new battery for it, followed the directions on pouring the acid in step by step, and trickle charged it over night. when i tried to start the bike, the battery only cranked for about 10 seconds. i repeated the charging process for 4 night and it still only cranks for 10 seconds and dies. I then ran tests on the battery, which all said that it was in good working cond. what could be the problem with the bike that is causing this to happen? i am new with bike so i diagram would be helpful if possible. thanks a lot.
Old Sep 19, 2009 | 01:18 PM
bmgcya's Avatar
1.When the battery, starter, etc., turn the engine over are you getting anything?
2. I would get a new battery as it should have came charged if you got it from a dealer.
Actually adding the acid charges the battery about 80%.
3. If the battery is not the problem, look into your regulator/rectifier.
Old Sep 19, 2009 | 01:49 PM
Krux's Avatar
Get a DVOM and check the voltage at the battery. See how many volts like 12.4 would be acceptable. With this if you can get it to crank over and turn on see what the out put is from the alt like 14's would be nice.
Old Sep 19, 2009 | 08:33 PM
duececivic's Avatar
it sounds like the rectifier is no good turn it over and take a reading then u need something in the 14s to charge the battery
SnakeTheLegend
Oct 15, 2010 09:40 AM
97turboeco
Dec 14, 2009 01:18 PM
rslaney
Sep 17, 2007 03:02 PM
bamzo25
Apr 28, 2007 10:30 AM
cassimero
Aug 2, 2006 01:26 PM
