Battery Power Switch
Old Dec 21, 2012 | 10:52 AM
R3define's Avatar
Default Battery Power Switch
So I bought an LED clock for on my bike. It says I need to wire a positive, negative, and a power switch. What can I wire the power switch into? Just like one of the gauge lights?
Thanks
Old Dec 21, 2012 | 12:04 PM
74demon's Avatar
The power wire needs to go to a power source that has power with the bike off. This is for the memory to keep the time. The switched power is for the light/display. It should go to a power source that has power with the key in the run position. The ground just goes to a ground or splice into a ground wire.
Old Dec 21, 2012 | 12:32 PM
R3define's Avatar
I knew the power/ground. But what's a good place to tap in for the switched power?
Old Dec 21, 2012 | 12:37 PM
74demon's Avatar
I would tap into the dash lights circuit. It's close and doesn't draw on the cranking circuit. The LEDs shouldn't put too much load on the lighting system.
Old Dec 21, 2012 | 12:39 PM
R3define's Avatar
Awesome. Any particular wire or it just needs to be a power wire to one of the lights correct?
Old Dec 21, 2012 | 01:26 PM
74demon's Avatar
It will be the power wire that has key power only in the dash illumination. Use a test light, DVOM, or look at a wiring diagram to determine which.
Old Dec 21, 2012 | 01:28 PM
R3define's Avatar
Thanks!
BrianCWhalen
Aug 16, 2015 10:30 AM
mtbr_mark
Jul 10, 2013 11:54 AM
jjnord
Aug 30, 2011 05:20 PM
cmasonrun
Sep 19, 2008 09:03 PM
fishfryer527
Apr 17, 2007 08:53 PM
