back tire
Old Oct 9, 2006 | 04:32 PM
bubba_d_duck's Avatar
Default back tire
ok i am going to be replacing my back tire is there any trick or any thing that i should know before i take off the back tire or is it pritty simple. just unbolt slide chane off take tire off?
Old Oct 9, 2006 | 07:08 PM
VaN_NaV's Avatar
Default RE: back tire
Like, you want to change your tire?
Um, pretty much to take off rim and stuff yea, unbolt and don't misplace your parts (get parts bins) and put **** back together how it came apart (get a manual).
Uhh, to change the tire... Its a little harder, break the bead with weight (don't use anything to pry it) then kinda push the tire off the rim, to get the new tire on use a combination of soap and water and put on the rubber of the tire and it will slide back on the rim. Go get it balanced (computer is fast and cheap like 5 bucks). Then you should be set.
One more thing is to make sure you seat the tire with air pressure (you will have to make sure the bead seats right and don't put more then 70psi into a tire.).
Old Oct 9, 2006 | 09:46 PM
i'll tell you what its a pain trying to break that bead off the rim i just gave up
Old Oct 9, 2006 | 10:01 PM
http://www.clarity.net/~adam/tire-changing-doc.html
check this site out i think i am going to try this
Old Oct 9, 2006 | 10:39 PM
mikequinn's Avatar
Have you got access to a vice? if so put the wheel in the vice to break the bead otherwise it's off to the tire fitters.. also make sure you put the tyre on properly some have dots on that have to be lined up with the valve & some dots go opposite the valve make sure you check 1st, most use yellow or red dots...most of all make sure it's safe.. for what it costs get it done profesionally, and you get piece of mind, & you'll be safe
CBRALF4ME
Aug 27, 2010 06:28 PM
dawoonj
Jun 15, 2009 12:09 PM
mgeanta007
Oct 15, 2007 06:59 PM
jasonb
May 7, 2007 06:56 PM
KNEE DRAGGER
May 6, 2006 06:51 PM
