anyone teach me how to sync carbs?
Old Aug 31, 2005 | 02:55 AM
wht92cbr's Avatar
Default anyone teach me how to sync carbs?
anyone have any websites or any methods on how to sync carbs? much appreciated. thanks
Old Sep 1, 2005 | 08:50 PM
slowpoke's Avatar
Default RE: anyone teach me how to sync carbs?
Both carbs and fuel injectors can be synched. It's a means of making each cylinder do it's share. You need a set of vacuum gauges or mercury tubes. I use a set of mercury tubes called "Carb Stix", with four long tubes sitting in a mercury supply. I bought it over 20 years ago and with the mercury they might not sell them anymore.
Each tube has a rubber hose that connects to a vacuum take-off port on the intake manifold or inner part of each carb. The vacuum from each cylinder pulls up the mercury to a certain height. You turn a screw on each carb to balance out the mercury levels. With vacuum gauges, you bring each carb to the same vacuum number. On my 1000, #2 cylinder is the base and the other three carbs are set to it. Don't try doing it without the mercury sticks or vacuum gauges.
this guy
Jan 19, 2014 01:08 PM
lilgeezy
Mar 4, 2010 04:38 PM
CoreyAkaOpie
Jan 31, 2010 04:02 PM
acat04f6
Jan 14, 2010 05:07 PM
Laststop
Sep 6, 2005 11:28 PM
