Anyone good w/ wiring know if this is good or will work for the F2?
Old 08-20-2012, 09:16 PM
underground-mpyre's Avatar
Default Anyone good w/ wiring know if this is good or will work for the F2?
https://cbrforum.com/forum/how-tos-8...ensive-139800/
Old 08-20-2012, 11:07 PM
74demon's Avatar
Yes, it should work just fine.
I would wire it differently, or try to, but since that way works...do it that way. I need to run my way by SB to see what he thinks about an alternative way. One of these days.
Old 08-21-2012, 12:54 PM
Kinda curious to even a Hp or better burn difference to my already Iridium plugs.
Old 08-21-2012, 03:26 PM
74demon's Avatar
It should run a lot better and start easier. Your putting spark right to the plug instead of going through a wire that is designed to have lots of resistance, inconsistent resistance, and take time for the voltage to go through, not to mention that each coil fires 1 plug instead of 2.
Old 08-21-2012, 03:53 PM
The idea as a collective looks great on paper, especially next year my bike hitting 20 years old. I am kinda skeptical and hesitant on doing this. Seems like a cheap fix to cold mornings. Anyone with a F2 done this with no problems?
Old 09-13-2012, 12:57 PM
quartazz's Avatar
I will be attempting this mod this weekend using f4i coils, and will keep you posted on my findings...if anyone is interested.
Old 09-13-2012, 01:02 PM
Thanks, just make sure the Ohms output is the same before attempting please.
Old 09-17-2012, 10:52 PM
quartazz's Avatar
Progress thus far.....it has been pouring rain her for the last three days but the info I have as far as ohms are concerned are this....my stock coil setup ohms out at 3.2 ohms. My donor stick coils (denso model number: 129700-3881) ohm out at 1.3 ohms each. So when I series the stick coils I get 2.6 ohms respectively. (A difference of .6 ohms). My coils are old and worn out, I was wondering if anyone else has ohmed out there stock coils so I can have a reference point, and if the .6 difference would cause a problem with my bike if I installed the coils....thoughts?
Old 09-17-2012, 11:03 PM
quartazz's Avatar
I went back and checked my math of the ohms of my stock setup, and I found out that I forgot to subtract the ohms of the leads of the stock set up...which turns out to be .3 ohms, per lead. So once I subtract this .6 ohms, I get a net 2.6 ohms. So the stick coils I picked seems to be a spot on replacement for my factory setup. So I am going to install them and see what happens.
Old 09-18-2012, 03:34 PM
Please keep me(us) informed on how this works out. I am back to slowly building up my big bore motor and would like to have a better option to outdated spark.
Quick Reply: Anyone good w/ wiring know if this is good or will work for the F2?
