Air box / air ram routing
Old Oct 22, 2009 | 10:18 PM
OutToWin PAHC's Avatar
Default Air box / air ram routing
When I picked up my F2 in the box of extra parts was the air ram box. But its for an F3 I think. The bike has full 97-98 fairing by the way.
So I want to connect the ram air box to the air box, but I don't see how. The air box lid has two air tunnel tubes that turn down behind the V of the frame and go nowhere.
I have been checking google images and the exploded view on bike bandit.com, but I have no idea how connect the ram still.
Does anyone know? Or have photos.
This is what it looks like.
Old Oct 22, 2009 | 11:10 PM
Kuroshio's Avatar
Got a pic of the air box?
Old Oct 23, 2009 | 06:03 AM
Kurtz's Avatar
I can't see how this is meant to fit. The Ram-Air get-up of the F3 is a totally different system to the F2. You'd probably need to re-jet too. My guess is the guy bought it intending to fit it and gave up because it was too tricky. Your F2 based bike is designed not to have the ram-air.
(One bodge I've been told about mind, is that if you saw off the 90 degree snorkels from the F2 airbox, you get a bit more throttle response..)
Old Oct 23, 2009 | 08:22 AM
cowboy from hell's Avatar
dont do that your bike has no ram air and is not meant to have it. if you cut your snorkels your bike will run like **** same reason why kn filters steal power........f3,s have a fuel pump,bigger pilots and 2 different jet sizes. their built to run ram air. only way to make it work is f3 carbs and (if not a fuel pump) some way of getting enough gas to the carbs.(jerry rig)
Old Oct 23, 2009 | 08:47 AM
Kurtz's Avatar
Kind of shot myself in the foot there!
Old Oct 23, 2009 | 08:39 PM
Oh ok the snorkles almost looked lime something else was supposted to go onto them. I never knew the F2 never had an air ram. Kinda crappy how it picks up the air above the header and from behind the radiator.
Old Oct 24, 2009 | 04:58 AM
it would seem so but higher air volume does bad things to these bikes. thats why kn says flows 50% better than stock yet has no corresponding hp numbers. what i meant was dont cut the snorkels kurtz.
antatious
F2 Tech
Sep 15, 2024 11:51 PM
MikeInCtown
Jun 2, 2011 09:55 PM
ineedparts
Apr 10, 2011 12:55 PM
87turbobuick
Apr 3, 2011 02:41 PM
cookiemonster
Aug 24, 2008 10:57 PM
