Acceleration Problem
Old Nov 24, 2005 | 11:46 AM
ken863's Avatar
Default Acceleration Problem
I have a problem,
the first few gears the bike will scream up the rpm gauge, but when I am in 6th gear and twist the throttle, it just bogs with no RPM gain, I have to baby the throttle in 6th to get it up to 70 or 80 mph.
Any thoughts out there?
Old Nov 24, 2005 | 02:55 PM
MofoSachem's Avatar
Default RE: Acceleration Problem
If your engine dies while the throttle is maxed, you might be flooding the engine, or not getting enough fuel, but you did say that it workz for the other 5 gears. Reguardless i think you are going to have to break down the fuel system, and check the in and outs of the fuel flow, and carbs.
Old Nov 24, 2005 | 07:23 PM
ken863's Avatar
The first 4 gears it will quickly redline., But in 6th with max throttle it does not increase in RPM, like if you are in 6th at 6000 rpm and nail it, it stays at 6000 and surges like it wants to take off but can't.
Old Nov 24, 2005 | 11:30 PM
dc_220's Avatar
are you running your gears up or are you doing the "correct shift". I can hit 70 to 80 in first no problem.
Old Nov 26, 2005 | 03:39 AM
clemson725's Avatar
too rich.
Old Nov 26, 2005 | 11:50 PM
Destinmatt's Avatar
sounds like your in to high of a gear. what RPM do you cruise at? I stay around 6-7K doing 80 in 4th.
Old Jan 1, 2006 | 10:48 PM
ken863's Avatar
Okay, If anyone is interested I fixed the problem.
I ordered a Dynojet jet kit and installed it. I noticed that the original Jets were 132's and the largest jets that came with the DynoJet kit were 126's. I went ahead and installed the kit. During test drive it still had the acceleration problem, but not quite as bad. I Emailed Dynojet asking why the largest jet in the kit was a 126 and they said that they number their jets differently than anyone else,, ummmm okay.
Since it did run a little better, I went ahead and ordered a Jet kit that came with 140, 145. 150 and 155 size jets.
I installed the 140's today and they look about 1/3 larger than the Dynojet 126 jets. Test drove it and it ran GREAT!!
Morale of the story,,, TOO LEAN!!! needed more Fuel.
Old Jan 16, 2006 | 03:14 AM
wht92cbr's Avatar
i have the same problem man!! are you sure its the jets? um.. i know this will definately sound like a newbie question but um what are the dyno jets? are they injectors or something like that. ok any help would be awesome!
Old Jan 16, 2006 | 07:55 PM
ken863's Avatar
Okay, Dyno Jet is a manufacture of re-jetting kits. It comes with new jet needles and Main Jets. You have to remove the Carburators and replace the Jet Needles and remove the Float Bowl to replace the Main Jets.
I have done a little more experimenting since last post. I installed 145 main jets and then installed the original Needles and it ran like Crap again, I put the Dybo Jet needles back in and it ran great again. The biggest correction comes with the needles.
nsuhtrack
Apr 23, 2008 11:24 PM
amig
Feb 28, 2008 12:39 AM
madmike01uk
Jun 8, 2007 03:17 PM
amey200
Aug 23, 2006 04:39 AM
nswhite
Aug 6, 2005 11:37 AM
