94 F2 Battery charging-help
Old 09-27-2008 | 12:52 PM
ddesens's Avatar
Default 94 F2 Battery charging-help
I have a 94 cbr f2. check batt voltage engine off=12.96. Check voltage while running 12.5. Check voltage while revving at 6000 voltage higher but still under 13volts. What do you think. Battery was new 2 weeks ago when I first put it on the road. I only work 2.9 miles from home and that is really the most I have ridden it. I only get to hit 55mphfor a few seconds during this trip. The regulater seems to get extremely hot while the bike is running. Is this normal? This is all stemming from my battery being dead when I went to go to work yesterday. Pop started it after work got home and it wouldnt start again. Not enough running time to recharge?
HELP!
Old 09-27-2008 | 01:00 PM
SalemCBR's Avatar
Default RE: 94 F2 Battery charging-help
You need to buy a new regulator. Your regulator should be ~13-14.5 when revving to around 5k.
My F2 is doing the same thing right now. If you took your 2 week old battery to a bat store, they'll probably find problems already. The regulator gets hot, but a bad regulator gets hotter. Some people put an extra ground on the regulator, some even put a computer fan on it to keep it cool. But mostly you need a new reg. 160.00 from honda.
I've heard of people putting gixxer regs in to thier hondas to help too. Just don't go buy a used honda reg, that's for sure.
hmm
02-05-2015 01:10 AM
njdjh2o
04-11-2008 08:20 PM
dachamp312
01-20-2008 09:47 AM
bryans 86
07-20-2007 08:58 AM
weeble1
05-10-2006 03:35 AM
