'93 F2 Mods - Phase 2
Old Apr 17, 2013 | 01:23 AM
  #221
richbransby's Avatar
Looks amazing JNS.
That shorter exhaust really suits the fairings and i beat it sounds awesome.
A world apart from Swamp Thing.
Old Apr 17, 2013 | 06:14 AM
  #222
Arn1016's Avatar
Looking great as usually just! Good news my bike should be back Friday! It was Spendy (won't thread jack)
Arn
Old Apr 17, 2013 | 10:28 AM
  #223
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Originally Posted by R3define
Wow!
That looks amazing. Love all the logo's, sponsors, etc.
Thanks, I'm happy with it, as it needed a little bit more color - the black/red/yellow only, was still just a touch bland.
I just bought a Cheetah Race fairing set and it looks pretty similar to yours (can't remember what race fairings you have). I'm excited to get them mounted and painted.
Yeah, these are also Cheetah fairings.
Oh. Also, your tail section, do you have a single seat or is it the regular seat that just goes under the race tail?
Yes and no... the supersport style tail, does employ your stock seat, and covers the pillion, but in my case, as you may remember from a previous post, I bought an additional seat, uncovered it, cut it down, and recovered it, so that it's kind of a "makeshift" single seat, which is somewhere between 1 1/2 lb. and 2 lb. lighter than the full seat.
I will run it like this for this season, but next year, I will be going with the F3 superbike tail, and using the foam seat pad - that tail looks like this:
Old Apr 17, 2013 | 10:46 AM
  #224
JNSRacing's Avatar
Originally Posted by richbransby
Looks amazing JNS.
Thanks Rich! Yeah, it did just occur to me, that though I shortened that can almost a year ago, this is the first picture of the bike "fully dressed", since then.
Oh, and yes, it does sound very nice!
Old Apr 19, 2013 | 03:49 PM
  #225
R3define's Avatar
Is the advantage then to just gain a lighter seat?
Old Apr 19, 2013 | 04:14 PM
  #226
JNSRacing's Avatar
If you're talking about the advantage of that F3 superbike tail, that I will use next year, than yes, that's one advantage, but there are several.
1) Let's face it, the F2 and early F3 supersport tail, like what each of us have, which employs the banana seat, is fat and ugly - it looks like a boat from the rear! So, firstly, the tail I'm after is just plain better looking than the current one!
2) It has a more aerodynamic profile.
3) Using a thinner foam seat pad, allows you to get more feel from the bike on the track, namely what's going on with the rear suspension.
4) Lastly, yes, weight savings... that piece of foam is only a few ounces, but the OEM seat is almost exactly 4.75 lb., not counting the mounting bolts and washers. Even if you remove the passenger hold strap and its accompanying hardware, including yanking out the square-head bolts from the plastic base, the seat is right at about 4.25 lb., and a location up high like that, is a good place to lose almost 5 pounds!
Old Apr 23, 2013 | 09:09 PM
  #227
R3define's Avatar
You and your weight savings. Haha. So I haven't decided if I'm going to try and make my Cheetah fairings work, but, what did you use to connect the front fairing to the underbelly piece? You have 3 screw like things that look like they connect.
Old Apr 24, 2013 | 10:42 AM
  #228
JNSRacing's Avatar
Uppers connect to lowers with Dzus fasteners - Kurveygirl.com for these:
KurveyGirl - Motorcycle Stuff: Dzus Fasteners, angled valve stems, Vesrah and More
You should have three holes on each side (I'm thinking you'll still have to drill yours), and to further stabilize the lowers, once you have mocked up the uppers and lowers (on the bike), and get the appropriate holes drilled for the Dzus fasteners, you should drill a hole on each side, for the rear-most lower mounts that were employed for the OEM-type plastics... the mount circled in green in this pic, and the corresponding spot on the other side.
Old Apr 24, 2013 | 11:11 AM
  #229
R3define's Avatar
Do you know if you can get those in black? All I saw for the S-Spring type were the chrome ones, I see that you can get D-Ring type connectors in black, any downfalls to those instead of the S?
Old Apr 24, 2013 | 11:38 AM
  #230
JNSRacing's Avatar
Well, the D-Ring portion is used either way, the difference in the kit I use, and the kits with the black D-Rings, are the retainers. I have only used the type in the link, but I don't see why the others wouldn't work... it seems to me, that the S-Spring retainers get a better "bite" from the D-Rings, if that makes sense.
