92 cbr 600f2 won't start
Old Jan 22, 2017 | 04:09 PM
hectorbuentello's Avatar
Default 92 cbr 600f2 won't start
Guys can y'all help me here I got a 92 cbr 600f2. I was riding one day everything seemed fine but the next morning when I tried to started it it wouldn't even crack it wouldn't just click. So I thought it was the battery I got a brand new battery I checked the stator I connect some cables to the stator and it worked but when I try to start the bike up and it just clicks on the solenoid once. So I'm thinking it's the solenoid? Any advice ?
Old Jan 23, 2017 | 02:59 AM
Scorch's Avatar
Try putting the bile in gear and push to see if the motor is not stuck, I've have a leaking fuel tap that filled a cylinder with fuel and when I tried to start it the piston got stuck at top dead and the starter would just click.
Old Jan 23, 2017 | 03:19 AM
CaBaRet's Avatar
Hi ,try bridging the two terminals on the starter solenoid, if the engine turns then its the starter solenoid that wants replacing, you will find how to do it on You Tube
Old Jan 23, 2017 | 05:26 PM
The solenoid just clicks once I tried by passing the solenoid and nothing it just clicks once I connected the starter to my charger and the starter turns but the engine won't turn over or crank
Old Jan 24, 2017 | 03:24 AM
CaBaRet's Avatar
Hi, are you saying the starter motor will spin with voltage put to it?will it start of a push/bump start
Old Jan 24, 2017 | 10:24 AM
Yea it'll spin but the engine won't turn over or crank and no I haven't tried push starting it
Old Jan 24, 2017 | 10:43 AM
CaBaRet's Avatar
Hi, it looks like either your battery or the starter switch, I know you said you got a new battery, but it wont be the first time that they have failed, first of all take the battery off the bike give it a good 24hr charge ,pop it back on and see it will start, as you press the start button look to see if the headlight dims, if as you said the starter clicks , then the starter switch could be ok, but a good battery charge in the first place
CBR-J
Aug 16, 2017 09:19 PM
HenryF
May 26, 2012 01:18 PM
pskillman
May 1, 2010 06:45 PM
cbr714
Jun 10, 2007 07:55 AM
