91 Honda CBR F2 - broken pressure plate
ok thanks guys. I got the nut off and out of excitement just pulled the clutch basket and clutch plates without thinking to look to see if it needs to go back on a certain way.
Does it matter how I slide the clutch basket back on? I know the order of the washers, but do certain splines need to match up?
I have all the plates out and the center nut off but i need to get the clutch basket out. I can not get it to clear the gears on the right corner. Is there a way to take that bolt out of the center? Or is there a way the washers in between the center bolt and outer clutch basket come out?
you do not need to jam the wheel or even put it in gear. Use an impact wrench and do quick short burst until it loosens, you do not want to do any more damage then has already been done. Ohh and befor eyou try to get it off make sure you undo the stake in the nut. If you need any parts, my motor is in pieces and everything is in good shape. LMK
