91 F2 starts and runs great, dies, sits starts again
Old 08-10-2007 | 06:14 AM
Jsalty's Avatar
Default 91 F2 starts and runs great, dies, sits starts again
Ive got a 91 f2. The fuel system is all cleaned from the tank to the carbs. I believe this problem is electrical/ignition related. after sitting for a while and cooling off the bike will start and ride fine with great throttle response for about 3 miles it will suddenly loose power and not start again for 30-40 minutes and same thing happens..
Any ideas?
Old 08-10-2007 | 09:32 AM
Viking's Avatar
Default RE: 91 F2 starts and runs great, dies, sits starts again
Regulator / rectifier problem perhaps? Sounds like your R/R is overheating. From what ive heard its a common problem for the F2's.
Old 08-10-2007 | 09:51 AM
MikeInCtown's Avatar
I'd agree that you should look at the R/R problem first, but only buy a cheap used one to test out. Could also be a carb vapor lock type problem, but my bet is on electrical for now.
Old 08-10-2007 | 12:17 PM
MT Wallet's Avatar
The rectifier may not be charging the battery 100% and so the battery dies....then you let it sit and the battery slowly regains charge.
You start the bike again, only to have the r/r charge it partially and the cycle continues
Old 08-10-2007 | 02:53 PM
Jsalty's Avatar
r/r is a possiblity but i am leaning towards ignition pulse generator or something on the ignintion circut..
Old 08-10-2007 | 04:43 PM
That battery is not going to recharge itself sitting there. if it doesn't have the juice to run the bike running, it sure as heck won't have the juice to crank for the restart.
Old 08-10-2007 | 05:53 PM
MT Wallet's Avatar
ORIGINAL: MikeInCtown
[&o]
Old 08-12-2007 | 01:49 AM
Jsalty's Avatar
vaccum line going to tank was kink and clogged..so for now it was vaccum lock that caused the problems...
raz478
11-21-2013 09:49 AM
mr93t
05-14-2009 02:14 AM
rschwan9
04-25-2008 02:16 AM
rschwan9
04-22-2008 08:15 AM
viva_brasil
04-04-2008 12:16 AM
