1st gear real jerky?
Old Mar 7, 2010 | 05:03 PM
live4liftin's Avatar
Default 1st gear real jerky?
I have a 94 and for some reason the 1st gear seems real jerky and 2nd is perfectly smooth. Does anyone have an answer for this? and whats a good RPM point to pull out of 1st? any other Do's and Dont's I should know. Thank you.
Old Mar 7, 2010 | 05:10 PM
Kuroshio's Avatar
Define 'jerky'. 1st gear is sensitive about throttle changes on any bike. Rip the throttle or slam it closed and its gonna be a bumpy ride (if it doesn't toss you for ripping the throttle wide open).
On my F3, I'm usually getting out as soon as I feel my bike can handle 2nd without worry of bogging out. Usually in the 4k range. I can short shift earlier tho
Old Mar 7, 2010 | 05:51 PM
Its very Vibrating like. Also One time i went to take off I wasnt thinking and made a bone head mistake and kicked the clutch down when I was already in 1st gear. I stayed in gear but can this do any serious harm. Thanks for the reply man............................................... ....................................
Old Mar 7, 2010 | 06:02 PM
Kuroshio's Avatar
Dunno bout vibration only in 1st. Might be something up with the tranny. But I haven't dealt with tranny issues yet so I don't know.
Old Mar 8, 2010 | 03:35 AM
RedBaron's Avatar
Its all about throttle control........ Got no idea what you mean by "kicked the clutch down", where you kicking the handle bar? haha....seriously though im sure a small shifting mistake wont do any serious harm.
Old Mar 8, 2010 | 12:53 PM
Bently600's Avatar
Kicking down on the shift lever when already in first will probably not hurt anything.
600cc Sport bikes have a lot of power and the throttle is pretty sensitive (especially in first) learn to be smooth with the throttle. If you are experiencing jerky movement it is most likely the fault of your right hand. I would suggest learning to ride on a bike with less power.
Old Mar 8, 2010 | 12:57 PM
Kuroshio's Avatar
Dunno... 'Vibrating' isn't a throttle control issue. Course terminology could be confusing things here.
Old Mar 8, 2010 | 03:15 PM
Sand.Man's Avatar
Check your chain tension, if it's sloppy that could be a contributing factor.
Shadow
The Hurricane Saloon
Jul 5, 2012 06:37 AM
tardbarn
Jul 7, 2010 02:06 AM
DDCavi
Apr 3, 2008 11:07 AM
Ruthless
May 11, 2007 12:11 AM
