06 cbr 600rr to f2 fairing swap ?
Old Apr 28, 2011 | 10:13 AM
  #31
adrenalnjunky's Avatar
Originally Posted by myfreshdcs09
I would really like to see a newer gsxr 600 swap. I love the headlights on them. Or maybe an R6 swap?
Hey i was lookin at my bike and noticed that the douche who had it before me cut the mounts for the fairing stay off. What do i do now? And while i was looking i saw that i had a puddle under my right fork!!!!!! WTF man, out of nowwhere? REALLY
Yeah - the 600rr fairings aren't going to line up with the factory fairing mount holes in the frame - you're going to have to create new brackets and mounts there. No one set way of doing it - will just have to figure that out once you have all the parts and pieces ready to roll. Fabrication skill is a must for that kind of work. Good thing about our bikes - steel frames mean you can tack-weld on a bracket pretty simply.
As far as the fork goes - if the prev owner used it as a stunt bike, the fork has taken a lot of abuse - stoppies and low-speed wheelies are hell on forks & seals. If it isn't brake fluid, then it is probably leaking oil out of the bottom bolt that holds the inner tube to the outer. You need to get a couple of 8mm copper washers, pull the fork tube out of the bike, turn it upside down, break the bolt loose, and replace the washer that is there. Torque the bolt back down to 17 ft/lb and put the front end back together.
You should probably do both of the forks at the same time, this probably resulted from a previous fork rebuild and they reused the washer that was there. That washer deforms as you tighten it, and if you take it out and reuse it, it doesn't fit exactly the way it did before.
Might need to add a little fork oil to the fork too to compensate for what was lost.
Old Apr 29, 2011 | 07:21 PM
  #32
myfreshdcs09's Avatar
Yea im pretty handy when it comes to stuff like that, but its hard because i dont know what anything looked like stock bc he chopped alot of stuff of the bike.
The oil is coming from the seal, i lifted the dust seal and took a business card and kind of curled it aroung the forks to get iinto the seal and wipe out whatever crap was in there but no luck. I cant really find a walkthrough for the replacement of the seals either.
Thanks for all your help bro. Appreciate it. PEACE
Old Apr 29, 2011 | 10:01 PM
  #33
these are pretty close to the process:
https://cbrforum.com/forum/how-mecha...-f4-f4i-41756/
https://cbrforum.com/forum/how-mecha...-video-111548/
Old Dec 13, 2011 | 08:44 PM
  #34
HuskerRed's Avatar
Been looking at the F2 conversions extensively and this one turned out really well. I have been looking for something on the 07- 600rr fairings on a F2, just to see, but only found the fighter in the F2 gallery. Just curious if anyone has seen a F2 to the newer 600rr conversion or opinions on that one? I did come across one thread (https://cbrforum.com/forum/600-modif...1-tail-102256/) but the pictures weren't there any more (and it wasn't an F2).
Old Jun 5, 2012 | 05:59 PM
  #35
azndan's Avatar
New Member
Originally Posted by kustomcbr600rr
Love this bike, i just bought the a 05-06 600rr fairing set and am having troubles lining it up qutie right, can't get mine to look as good as yours, wondering if you had any pictures of getting the front fairings set and front cowl, if you could e-mail me at dgarry535@gmail.com
thanks
Dan
raiden571
Dec 3, 2024 09:17 AM
JDean
Jul 18, 2011 10:51 PM
jman21lax
Jan 24, 2011 10:18 PM
a2nryc3
Jul 28, 2009 07:33 AM
mvergara79
Jan 25, 2008 05:23 AM
