Fork Adjuster update for older Hornets?
Old Apr 22, 2026 | 05:48 PM
burnt44's Avatar
Question Fork Adjuster update for older Hornets?
I have a CB600F "Hornet" model PC41 from 2007 which has an upside-down fork that is not adjustable.
The same model code PC41 was used on the "CBR", sharing engine, frame and most other components, adding a fairing - and the same fork, but with adjustable rebound damping and preload.
Now by the parts catalogue it seems that my fork can be upgraded to adjustable just by adding the "Bolt comp, FR Fork" part - see here.
Can someone confirm this?
Old Apr 23, 2026 | 01:31 PM
Ed Harris's Avatar
As far as I understand, it was the CBR600RR (PC40) that had the adjustable forks whilst the CBR600F (PC41) reused the Hornet forks.
The RR internals look significantly different and I doubt that it would be as easy as just changing the one component - more like a front end swap.
Old Apr 24, 2026 | 04:57 AM
burnt44's Avatar
The PC40 parts may be totally different, here we are talking only about PC41 variants.
Some PC41 models from 2007 on and (AFAIK) all after 2009 had adjustable forks, in both Hornet and CBR600F models.
This parts catalogue page shows both variants in one picture - and obviously both use the same damper (#9).
BUT - using a USB endoscope camera to look down inside the damper where the rod ends - I found a drop of glue blocking the opening.
So it seems Honda anticipated the idea to upgrade the part - and decided to hinder such efforts.
Old Apr 24, 2026 | 08:09 AM
Ed Harris's Avatar
Then would the easiest option be to replace your forks with those from a CBR600F?
Old Apr 27, 2026 | 04:58 AM
burnt44's Avatar
Yeah, thanks for the lecture on plausible reasoning.
Old May 7, 2026 | 11:53 AM
burnt44's Avatar
To whom it may concern:
The CBR600F fork is identical on the outside and does fit an the Hornet models 1:1.
The inner parts are a bit different, the spring is 20 mm longer (and maybe softer), the preload adjustment has a travel of 15 mm.
The rebound dampening can be adjusted - but not the compression (as on the CBR-RR), and this would be desireable, because the stock (compression) dampening is too hard, seeing the front wheel jump even on slighter bumps. The spring is also on the soft side, leading to a sag of 40%. What I did:
1. Install slightly harder Wilbers springs (those made for Hornets needed a 20mm extension Alu tube)
2. Fill a 5W fork oil (10W recommended by Honda, 7.5W by Wilbers)
This lead to a clear improvement on bumpy roads, while retaining the precise handling on faster, even streets.
Also I increased the air cushion to 110 mm (from 100 @Wilbers, 70 @Honda) to make use of more of the 142mm free travel; measuring the max. travel with a zip tie.
Old May 8, 2026 | 10:47 AM
Thanks for the additional info.
Lets see some pictures of your Hornet.
Asmodeaus
Jul 13, 2024 06:41 PM
hawkwind
Aug 8, 2009 10:00 PM
catalyst.
Jun 9, 2009 12:28 AM
jahnaboi
Jan 18, 2008 11:04 PM
Richss1
Dec 11, 2007 02:25 PM
