wont stay running for more than 3 seconds
hey fellas! 87 600f wont stay running. was fine. 2 weeks ago i changed out the petcock to a working one. ran it after that and it idled fine for at least 20 minutes.
the other night i hooked up a new headlight, took apart the left handle to see about the bright/dim wiring. put it all back together and now it only wants to run for 3 seconds tops.
battery is DEAD. it runs for 3 seconds when jump started from my trucks battery (battery looks old so i figured i wasnt worried about battery damage if it happened)
or the other possibility is i flooded it with the new petcock, as i dont think i had it set properly. up-on, rear-off, down- reserve.
any help would be appreciated. thanks for your time.
Did you have to jump start it before working on the petcock & wiring/headlight, or did this start happening after? Also, how long have you had the bike & did it run well before this stuff was worked on & for how long? This will help with narrowing down the cause of the problems you're having.
The first thing I would look at is the battery itself & the connections to it. Either charge & test the battery or replace it, and make sure it has solid connections to both power and ground. If the battery is no good there isn't a reliable way to test the rest of the system.
no i never had to jump start it before, it ran great the few times i have rode it.
i took the battery to work and trickle charged and load tested it and it checked out.
this bike is a street fighter setup from the previous owner so all the wiring is tucked under the gas tank. so i will be doing some inspecting today now that i have some free time.
Sounds like there might be a parasitic draw and/or a shorted wire somewhere too, check the battery voltage and see if it has been discharged while sitting. Definitely a good idea to check all the wiring for shorts, bad connections, etc. If you have a multimeter I would be curious to see what the amperage draw from the battery is with the bike shut off (parasitic draw test).
Since it ran fine before I would first look at the handlebar switch & wiring, all the main harness wiring, or anything that was in the general area being worked on. I'm not suggesting you did something wrong, but if the previous owner did a crappy job with the wiring all it could take is moving a wiring harness slightly to short a wire. Also make sure to check all your fuses! Including the main 30A fuse that's separate from the fuse block.
so i took the handles back apart. i think my choke cable was somehow causing it. the bike will run now, but once i turn the choke all the way off it idles kind of rough. and then if i try to throttle up it dies.
Do you have a fuel filter installed? Maybe it got some debris in it, or in the carbs, when you changed out the petcock. What you are describing now sounds like a lack of fuel from dirty carbs.. running lean.
