Wiring Problem
Old Apr 14, 2007 | 08:05 AM
bing069's Avatar
Default Wiring Problem
Hi, new boy here from England!!!
I've posted this already on the new users forum so apologies if you already read this!!!
I have a 1989 CBR600 which is great, apart from one little problem..... the front and rear lights flicker and dim when the indicator is switched on- does anyone have any suggestions??
Old Apr 14, 2007 | 08:32 AM
cbrf1's Avatar
Default RE: Wiring Problem
DO YOU MEAN JUST THE SIGNAL LIGHTS?IF SO IT SOUNDS AS SIMPLE AS A BAD GROUND WIRE.CHECK OUT ALL YOUR GROUNDS FIRST.I HOPE THIS HELPS
Old Apr 15, 2007 | 12:46 AM
HurricaneForce's Avatar
Could be a charging or battery problem as well. Does it do the same thing when you rev the engine? Try holding the throttle at 5k rpms and see if you still get the dimming problem.
lilbushhead
Apr 1, 2010 11:50 PM
tuai rumah
Jan 13, 2009 07:34 AM
HAVOC
Jan 18, 2008 09:52 PM
SomeName
Apr 12, 2007 04:04 PM
Kuczus
Feb 16, 2006 09:09 PM
