will a 90 f1 motor work in a 88
Old Oct 7, 2009 | 08:12 PM
joshcu01's Avatar
Default will a 90 f1 motor work in a 88
i have an 88 f1, went today and bought used motor and carbs from a cycle shop down the road. i new that thier is differences between all the years, my question is i went to hook up the genarator pulse wires up and the plug on the main harness have 4 wires and the plug coming out of the motor have 2, i cant remember if my old motor had two or four. now it wont start bc thier is no spark, im pretty sure thats my problem but i would like advice. thanks josh.
Old Oct 7, 2009 | 09:48 PM
KongBastard's Avatar
do a search. there are some changes that need to be done.
KongBastard
Old Oct 23, 2009 | 01:06 PM
wig's Avatar
wig
Default hh
I had the same with my cbr400 (nc23) i just removed the cover , and the loom attached, and fitted the pulse generator cover from my old engine, it was a straight swap, bit of a fifddle makign sure the starter motor guide bearing didnt move, but it fitted and worked fine
Old Oct 24, 2009 | 08:39 PM
Gogar's Avatar
YES as mentioned, you need to pull the left cover off of your old engine, get the 4-wire trigger system and the trigger sprocket with (5?) fingers. Put it on the '90 engine in place of the 2-wire trigger and the sproket that has (9?) fingers. That way your 88 CDI will work properly, and it should start up just fine!
I went through the same thing, tried to start my frickin bike for 2 days before I figured it out.
Phil R
Jul 13, 2021 10:36 AM
01.CBR.600.F4i
Apr 30, 2012 03:53 PM
HarleyZ28
Apr 28, 2011 07:03 AM
Dolinfmx
Apr 12, 2010 09:56 AM
jeepinkeif
May 17, 2005 01:32 AM
