Transmission question.
Old May 8, 2011 | 08:51 PM
Bizzyb's Avatar
Default Transmission question.
Bike won't shift into neutral while running only when ignition is cutoff, shifts into and holds every gear. What could cause this???
Old May 8, 2011 | 08:53 PM
9-5=4rr's Avatar
Is your clutch cable adjusted too loose ? ... I've heard of bikes being difficult to shift into neutral if the clutch is dragging and has tension on it from a loose clutch cable ... care to check that ??? ...
Old May 9, 2011 | 09:07 AM
Bizzyb's Avatar
Thought about that and adjusted it before I posted. Still no difference.
Old May 9, 2011 | 03:14 PM
tds94probe's Avatar
This is no doubt a clutch problem, most times this problem occurs is due to the clutch freeplay and the clutch not fully disengaging the engine from the transmission. When you adjusted it, did you adjust it at the lever end or the clutch side cover, from the side cover there should be slight tension on the cable, your freeplay is adjusted at the handle. When was the last time your clutch was done? What type of oil are you using?
Try this, when you have it in gear and bike running, pull the clutch in all the way then release it to the point that you can feel the bike start to drag a bit, then pull it back in ever so slightly and try to put it in neutral. If it goes into neutral, you need to readjust your clutch.
Old May 9, 2011 | 06:41 PM
Bizzyb's Avatar
Thanks for clearing that up TDS, got it to go into neutral, I adjusted the cable to tight, I adjusted it from the clutch side cover. As far as oil I have no idea, I'll check that asap.
Old May 10, 2011 | 06:49 PM
tds94probe's Avatar
Sooooo the problem is fixed? Orrrr?
Old May 11, 2011 | 01:52 AM
Bizzyb's Avatar
No not fixed yet guess I just got lucky the first time I tried your method, seems like I have to try real hard and be careful with the clutch to get the bike into neutral while running.
Old May 11, 2011 | 04:49 PM
Bizzyb's Avatar
Scratch that last post, I re-adjusted the clutch cable again and now it goes into neutral just fine. Thanks for your help TDS
Old May 11, 2011 | 06:01 PM
tds94probe's Avatar
Deilke6
Apr 30, 2013 10:22 PM
CBR BoyRacer
Jul 2, 2008 08:55 AM
raving
Mar 28, 2007 11:04 PM
CaliCbrF4i
Jun 25, 2006 11:15 PM
lauj_boi
Jan 31, 2005 08:27 PM
