too much valve noise? *vid inside!*
Is this too much valve noise? I just adjusted them, but I did so without the tappet adjusting wrenches so I had to readjust a few times after tightening the locknuts. am I paranoid or should I readjust now that I DO have the tappet wrenches? thanks guys!!
http://www.youtube.com/watch?v=sP0GGHEk-zY
Tappet Tool
Do you have a mechanical cam chain teinor? if so it may need adjusting and if you don't have a mechanical one you may need one.
it doesn't sound like a bad tensioner. that causes a slapping, rattling noise. i think in the video the only noise sounds like its comming from the valvetrain. did the noise get louder/more noticable after you adjusted your valves? has it always made that noise? it doesn't sound like anything out of the ordinary from the video. as long as the clearnance is ok after you tighten the lock nut, it doesn't matter what tools you used.
I've had nothing but trouble with the stock CCT both in my Hurricane and my 94 f-2 also its the same part and the only interchange engine part in the two. On the Hurricane I had trouble with the stock CCT at around 10,000 miles so I just bought a new one from Honda just to see what it sound like same noise as soon as I installed the new one, then I had a mechanical one made for it and no more cam chain noise and at 107,643 mile later with the same mechanical CCT (with just a few adjustments over the years) it sounds fine.
How did you get on in the end cbreric?
I think mine need doing aswell..
http://www.youtube.com/watch?v=i0aZq6filEs
What do you think?
Anyone got a guide on how to do it on the 1990 fl?
What do you think?
