Ticking sound
Ticking sound
Hi all, I hope someone can offer some advice to my recently delveloped problem. My CBR600FY has a ticking sound that only starts once the bike is warm. It goes however when I pull the clutch in. It is there through all gears and all rmp. I also have developed Clutch rumble which i understand is normal. Any suggestions??? should i be worried? it can be quite load sometimes. Gear change seems ok and the clutch is not slipping.
Potential problems I've considered is CCT (however would this not die down once the bike is warm?) Leaking/Blowing downpipes, Loose clutch basket, worn clutch. Maybe even something is loose.
Any suggestions would be great. Just sh*ting it abit in case I damaged the bike. miles is 16500
Cheers all
Cheers all
My vote would be loose clutch basket. Odds are the rivets are slightly worn that hold the basket to the flywheel causing it to chatter, which normally goes away when clutch is disengaged therefore this a very good indication that this is your problem. (Lever pulled in). Had the same problem on mine. Replaced the basket, it went away.
