Starting issues
Old 11-07-2012 | 10:48 AM
bburke88's Avatar
Originally Posted by CorruptFile
The choke works but restricting the air in the mixture to richen it, not by adding more fuel. Its normal to smell rich after cranking with choke, especially if the bike isn't starting.
So when its cold and in the morning, don't try it with just full choke, try half or so. These things take a little fiddling. I know the exact spot to set my choke in the morning, too much or too little and it won't go.
Failing this, I'd try checking your float levels. Its an often overlooked step in the cleaning/rebuilding process but can sometimes solve some problems.
Ok, I will do a little research and hopefully I can figure it out! I've never pulled the carbs apart, but im sure I can do it.
Thanks for your help.
Old 11-08-2012 | 12:34 AM
Zachy72's Avatar
Originally Posted by bburke88
Hi guys,
new member here.
I have a 1989 CBR600F.
Im having some starting problems. Shortly after I bought the bike, it was giving me issues with starting. It'll crank over and over before it finally fires. I usually have to give it throttle.
Bryan
By The sound of this, it would seem as though you are running rich... By having to crack your throttle you are allowing more air to enter, thereby leaning the mixture until suitable for detonation... in theory
Anyways to test this,
  1. perferably on a warmer day, start your bike up and let it warm up
  2. make sure your bike is at a steady idle and make sure you are on 0% choke
  3. slowly choke the bike, if RPMs decrease, you are running rich...
If this is the case, you get to pull your carbs again =] yay!
Please someone tell me if this information is not right.. I just started wrenching within the last year
Old 11-08-2012 | 11:02 AM
bburke88's Avatar
This sounds like the case to me.. in that case I should just take it back to the shop that did the work. It seems like the did a bad job.
Old 11-08-2012 | 12:37 PM
CorruptFile's Avatar
June 2013 ROTM
Unless there is a jet kit installed, or someone removed the mixture screw covers, the mixture should not have changed. Unless there is a problem with air restriction (dirty filter etc...)
AMSOIL929
07-16-2013 12:14 PM
graygeezer
06-15-2011 08:47 AM
cybr600
07-16-2010 07:42 AM
thegatekeeper14
07-11-2009 02:32 PM
ffry6326
04-08-2007 12:45 PM
Quick Reply: Starting issues
