Spark Plugs, Changing
Old Oct 15, 2006 | 08:59 PM
MRobe45515's Avatar
Default Spark Plugs, Changing
Any tips on the easiest way to change the spark plugs?
My neighbor suggests removing the radiator as the best solution?
Very little clearance, can't see how anyone could use a torque wrench
in such a confined space to dial in the documented 10 ft. lbs.???
Old Oct 15, 2006 | 09:57 PM
gixxereater's Avatar
Default RE: Spark Plugs, Changing
I wouldnt fret the torque wrench part. It will be ALOT esier if you can take off the tank and airbox. Otherwise, I've found on both my CBR's that the tool kit spark plug tool works the best. I think I used to actually just pull the side panels off (not the entire fairing) and reach in and pull them out. It wasnt too bad. I damn sure did NOT remove the radiator.
Old Oct 16, 2006 | 12:45 PM
rrasco's Avatar
yeah you can get in there and get em out without removing the radiator. its hard and frustrating, but it is possible.
Old Oct 17, 2006 | 05:21 AM
drakito's Avatar
FRUSTRATING is an under statement. Totally possibe to do, but be prepared for some knuckle rash and lots of swearing the first time you do it.
Old Oct 17, 2006 | 08:24 PM
MRobe45515's Avatar
I took care of the plug change last night, following your advice to go in through the removal of the air box.
The #3 plug was the most difficult to remove and the #'s 1&2 the easiest.
What I was surprised to discover was, the #1 plug wasn't snugged down???
So I guess, "if you want it done right, you'd better do it yourself!"
Thanks for the help guys!
Old Dec 4, 2006 | 10:40 PM
soul's Avatar
also having a 5" ratchet helps a lot too
Kona10
Mar 20, 2010 08:41 AM
Lampton64
May 20, 2009 10:57 PM
dragginazz
Apr 29, 2009 06:24 AM
chpanther69
Apr 19, 2007 10:23 PM
45th 929 guy
Feb 5, 2007 01:25 AM
