Running hot
Old Dec 3, 2010 | 12:44 PM
Big O's Avatar
Default Running hot
I have a 87 Hurricane, and when i ride it, the temp on the temp gauge goes all the way to the top of the white operating area and then the fan kicks on and cools it down a little bit. Then the process repeats itself. I flushed the system and it still does this? What else should I do?
Old Dec 3, 2010 | 02:03 PM
thrasher572's Avatar
Get out on the highway... They always have ran hot around town.
Old Dec 3, 2010 | 11:52 PM
Billistic's Avatar
Bah, ha, ha! Some of your answers are way too simple, however correct they may be!
Doctor, Doctor, my crotch gets hot when I ride my Hurricane around town!
Then stop riding your Hurricane around town.
Old Dec 4, 2010 | 11:46 AM
I can back the answer up with an explanation... The full coverage bodywork traps a lot of heat when there if poor airflow. Engine temp rises and the fan kicks in to regulate temp. The heat is not being forced out so it radiates through the bodywork and "cooks" your inner legs and other bits that make contact with the bike.
As long as there is adequate airflow this does not happen. Soooo....hit the highway.
Also this is not a new condition, they have done this since new.
Old Dec 4, 2010 | 01:55 PM
Big O's Avatar
98% of the riding I do is on the highway. but thanks for the "help".
Old Dec 4, 2010 | 01:59 PM
If its mostly highway riding then thermostat and water pump might be questionable... Do you have a service manual? The recommended test for the thermostat is removal and placing it in a pot of water. Heat the water and the thermostat should open between 176 to 183F the operation is sluggish(3 to 5 minutes to open). if it doesn't open replace it.
Old Dec 4, 2010 | 02:14 PM
It "helps" if you give more info. I didn't want to get you digging into the bike if your issue is a normal condition for the machine. So try to give us more info and we can try to give more accurate answers.
Old Dec 4, 2010 | 07:32 PM
Billistic's Avatar
and I thought you had a sense of humor.......Yes, I know exactly what you are saying and you are 100% correct.
Don't be talking about my "other bits" anymore on a public forum! :-)
Old Dec 4, 2010 | 07:43 PM
Its getting close to Christmas...Billistic nuts roasting over an old Hurricane, Jack frost nipping on your nose...
Old Dec 5, 2010 | 11:05 PM
Billistic's Avatar
You do have a sense of humor!
gundamknight07
Jul 26, 2012 08:24 AM
motogpman
Aug 28, 2009 07:10 PM
entity-unknown
Mar 20, 2009 11:55 AM
motoman358
Jul 2, 2008 08:59 PM
Kym
Jun 22, 2008 07:33 PM
