rough running
Old Apr 21, 2006 | 07:26 PM
eddie v twin's Avatar
Default rough running
Hi there , got a honda cbr 600 FL 1990, in the process of doing her up, got her started today and she ticks over at about 1000 too 1200 , but what i noticed is the 2 left cylinder down pipes seem to run hotter than the 2 right ones. She revs ok , but the tick over is very lumpy not at all smooth . Has new plugs fitted. any ideas people ??
Thanks Eddie
Old Apr 21, 2006 | 07:35 PM
brian's Avatar
Default RE: rough running
Interesting, have you checked valve clearences?
Old Apr 28, 2006 | 06:42 PM
well I've stripped the carbs down and cleaned them out thoroughly, checked the float hieghts and mixtures,flushed the tank out, fresh fuel and redex. She starts ok , I balanced the carbs ( out a bit ) . Checked the compression on all the cylinders 175 psi on all of them. But the 2 left cylinders still run hotter than the 2 right ones when you touch the downpipes ??. Any ideas at all ???
Eddie
Old May 1, 2006 | 12:09 PM
rrasco's Avatar
does it only do that at idle? i did notice if i leave my bike on the kickstand, the left two carbs get more fuel since the bike is leaned, did not know if that would cause them to run any hotter or not.
12stones
May 20, 2019 03:37 PM
victoruk2
Dec 8, 2014 09:02 PM
Tort93f2
Apr 13, 2012 12:18 PM
573v3
Apr 15, 2010 01:38 PM
ruckus724
Aug 18, 2009 10:23 AM
