Removal of rear wheel
Old Oct 27, 2012 | 04:30 AM
wickozxr's Avatar
New Member
Default Removal of rear wheel
hi folks im nige im having trouble removing the rear wheel on a cbr600f can any one tell me what the pros nj cons are of this many thanks
Old Oct 27, 2012 | 06:46 AM
87 cbr 600f's Avatar
hi nige not sure what kind of probs u having,usually not hard to remove rear wheel,start by loosening chain adjusters then axle nut,sprocket and carrier will come off too along with spacers for wheel
Old Oct 27, 2012 | 10:21 AM
CorruptFile's Avatar
June 2013 ROTM
^^ Yup. Pretty easy. There is a downloadable manual here
https://cbrforum.com/forum/cbr-600f-...1990-a-128286/
Old Oct 27, 2012 | 03:11 PM
xamdarb's Avatar
I have actually had a small amount of trouble removing my rear wheel, the rear brake mount was binding the axle and it would not slide out, try grabbing the rear brake caliper and wiggle it as you slide your axle out.
Old Oct 27, 2012 | 04:46 PM
dodger79's Avatar
Smile
I'd recommend trying to free any parts that are stuck with some penetrating oil. then use some wood and a hammer to get some movement started on the stubborn parts. start with gentle tapping and slowly give stronger ones. 'worry the part', stick at it - tapping and lubing. Don't get mad at it, just persevere and don't worry. If it won't budge after 10 mins or so just try and soak it and then do something else and have another go the next day. I don't know why but leaving stuff that is stubborn to remove comes away really easily the following day. My rear wheel spindle was fairly dry when I came to removing it but I got it out using this method. A block of 2x4 on the end of the spindle hit in a controlled manner with a rubber mallet got mine out eventually. you'll do it trust me.
malbojah
Apr 4, 2012 06:50 PM
ajzcamaro
Jan 18, 2010 08:44 PM
ninetyfivehp
Jun 20, 2007 06:27 PM
dwhite645
Jun 20, 2006 12:27 AM
Hytecrednec
Dec 8, 2005 08:05 PM
