rectifier mounts where?
so the bike is running after carb rebuild, plug wires replaced, oil etc... so the rectifier was uninstalled when I got the bike, the Clymer manual is vague about its placement and offers no picture... can someone shoot me a pic of where this goes, or guide me in its placement,.. looks like it has two bolt holes for it, left hand side of frame behind carbs assembly is useless to me.....thanks all! should be riding by june..
looks like i will need to zip tie it in, mounting hardware not with the parts ive got,.. no biggie...would it mount to under side of the cross member that also is used to screw in the bottom tab for the gas tank? Currently the ground is attached to the battery,, should i just screw the ground to the frame, or extend it back to the battery ground.. sorry for the noob questions, would have helped if the bike wasnt in pieces when i got it for po..
I did a thread on an r/r install NOT using the factory location. I wouldn't zip tie it tbh... Grounded to the frame is fine, I think thats how honda did it iirc.
https://cbrforum.com/forum/cbr-600f-...r-r-f1-147497/
