Recommendation Needed
Old Aug 11, 2010 | 02:28 AM
uptoodamlate's Avatar
did they change the fuel lines at the carbs for the 90? mine doesnt look like that at all, it has a tee between the 1/2 carbs and 3/4 carbs and then a seperate tee that connects those two tees, it has nothing between 2 and 3
Old Aug 16, 2010 | 01:50 PM
drumerboy3841's Avatar
hm interesting. I have no idea haha i though the carbs were a little bigger on the 90 so i imagine is a possibility. So update i got the carbs off finally. just ordered that fuel t. new problem by bike started burning oil its dripping of the the lowest point of the exhaust so obviously its coming from on the the cylinders. Any idea what that could be? i mean its probably the piston rings but im sure sure how serious this problem is or could become. Insight please
Old Aug 16, 2010 | 02:12 PM
adrenalnjunky's Avatar
Can you see where it is leaking from? you've also got an external oil cooler that might be the leak, and don't count out the filter leaking - both are off the front side of the motor.
Old Aug 16, 2010 | 06:34 PM
it leaks from where the header meets the extension to the slip on then drips to the lowest point. That is the only place i can find where oil is coming from.
Old Aug 16, 2010 | 07:53 PM
ahh - I thought you meant you had oil leaking onto your exhaust, not out of it. That doesn't sound good - although does the bike smoke any when ridden and are you noticing any real oil consumption between changes?
Old Aug 16, 2010 | 08:52 PM
im just in the process of finishing cleaning the thing up since i bought it. so i have not done any real riding. I just know that it has been running for a month now and ive riden it around the block and such and its been fine, but just a few days ago the oil started dripping, white smoke out of the exhaust, and the smell of burning something. Not exactly sure what though.
Old Aug 16, 2010 | 08:53 PM
o and it only really starts smoking after the engine is warm. If that means anything.
Old Aug 17, 2010 | 12:03 AM
I'm thinking a piston ring then. What grade/brand of oil is in it - might try switching, and even running something like some lucas oil treatment. Stuff did wonders on my wife's 626 with leaky valve seals.
Old Aug 17, 2010 | 12:09 AM
I dont know actually. All i know is it was new a few months before i bought the bike. what oil do you think is best? and ill try the oil treatment after i get the piece for the carb in the next few weeks. thanks a ton.
riclyd
Oct 17, 2012 04:23 AM
MenaceCBR
Mar 29, 2011 03:26 PM
929_boosted
Oct 28, 2007 01:57 AM
brazilianatuh
Feb 13, 2007 10:56 PM
viper
Feb 7, 2007 09:08 PM
