Parasitic draw with ANY regulator
Old Oct 18, 2020 | 05:25 PM
tkocher92's Avatar
Default Parasitic draw with ANY regulator
Good Evening,
I have an interesting problem here that is not easy to pin point.
When metering the negative post on the battery to its respective, unconnected terminal (leakage test), there is a constant 12+v parasitic drain on my battery as long as there is a regulator rectifier plugged in.
It does not matter which regulator, I have tried 2 healthy ones that have the same connectors, and have tested one different but healthy rr using alligator clamps. All are giving me the same reading.
if I unplug the rr from the harness, the voltage reading drops down to about .20~ volts.
The amperage reading remains at zero, although it does read 12+ Volts.
Old Oct 19, 2020 | 03:52 AM
UncleBulgaria's Avatar
One thing to note is that if the voltage is 12V and current 0A then the power consumtion is also zero (power = volts x amps) so there will be no discernable impact on the battery. So long as you have 0V when the ignition switch is in the Off position then this is pretty much as I would expect to see.
Gusto
Jul 30, 2008 07:38 PM
pasta847
May 3, 2007 02:15 PM
juan11cr
Mar 26, 2007 05:59 PM
Hoosier1104
Feb 6, 2007 12:54 PM
