Not supposed to happen?
You are right. It's not supposed to come out when you take out the axle. There is a hex head screw that holds the fork tube in there that is probably loose, hopefully not missing.
Tighten that up and you should not have that happen again. The axle probably was holding the fork oil in. You will notice the hole in the bottom of the fork where you can insert a hex wrench. Tighten to 14 ft-lbs.
07ceeberthousand
08-04-2009 06:53 AM
musantemike
07-13-2009 10:53 AM
