No Spark
Sorry, what I meant to say was when I turn the ignition to "on", the lights don't turn on, I didn't really notice it at first, I was too caught up in the spark plugs not firing. I replaced the ignition switch and starter relay switch today and still nothing. My battery is reading 13.8 volts.
Yes, I checked the Main fuse and all to other fuses last week, and all had continuity.
I found 12v at the ignition switch so I replaced it to see if it was bad. Still nothing
I will note this: The new ignition switch was aftermarket and lacked 1 wire at its connector. I don't know if it's the problem.
I also replaced the starter relay. I guess it could be the connector there but it looks decent and I got 12v from the yellow/red wire and green/red wires -> ground.
I've tried everything I can think of other than checking every single connection on the wiring harness.
Does it have a connector that fits the factory one or did you have to cut wires and splice the new switch in?
