no highbeams
Old Apr 12, 2009 | 04:30 PM
hypeshipe's Avatar
Default no highbeams
Hi all, finishing up the bike in time for the weather and have no highbeams, the light cuts off when i turn the highbeam on. The PO had a jaguar dual headlight on it and spliced in an extra connector. Any ideas?
Old Apr 13, 2009 | 12:07 AM
tripicana's Avatar
do you have an extra swich to turn on the aftermarket headlight? if its the stock switch, open it up and make sure all the connections are soldered. did you check for power at the wire on high beam setting? check the highbeam circuit on the bulb?
Old Apr 13, 2009 | 06:38 AM
Five's Avatar
Yeah, if it had always been a stock headlight, I'd say it was the bulb, but with the modification I would start by testing for power at the wire like Tripicana said.
Old Aug 17, 2009 | 10:16 AM
87cane rider's Avatar
Default check the starter button
i've had this problem too, I found jiggling the starter button will fix it. i know on mine the whole headlight cuts out. had a bugger of a time finding it
omg209
Feb 25, 2012 07:44 PM
greenc51
Jul 30, 2011 06:39 PM
snowboarding82
Nov 11, 2006 02:57 PM
asmulik
Sep 19, 2006 08:24 PM
