new fork seals
Old Feb 17, 2007 | 08:51 PM
mitchedwards81's Avatar
Default new fork seals
man i just got a new set of fork seals to replace my leaking seals while im doing this crazy upper swap, i was wondering if this is gonna be a pain to change.
Old Feb 17, 2007 | 11:57 PM
michigan_313's Avatar
Default RE: new fork seals
this will be easier if you can prop the front of the bike. this will allow easy removal of the forks from the triple clamps. go to ronayer.com and look at the exploded view of the forks from the microfiche. it's not too difficult to change the seals but a lot easier to do them off the bike. at the same time you can add in new fork oil.
Old Feb 19, 2007 | 01:18 PM
oldschoolCBR's Avatar
Also, in the shop manual it says to use a special honda tool to pound this metal ring back in once you put the springs back in, you can use a piece of pvc pipe, just bring a fork to home depot or something to get a piece that fits in the tube. I did the whole job in a little over an hour.
Another note, there is an allen head bolt going up into eachfork once you take the wheel bearing/bolt out, and those bolts were so tight, I couldn't get enough leverage on an allen wrench to get it loose, if you don't have a set of 3/8" allen heads (to use on a wratchet) you will need a set that are a few inches long. Or cut the "L" short part off of an allen wrench and find a socket that fits it on the other end. I had to have a friend hold the forks so I could tap the wratchet with a hammer.
Hope this helps, I wen't through the troubleshooting already, so hopefully you wont have to. Make sure to repalce the dust seals as well.
Old Feb 22, 2007 | 10:42 PM
xrvapunkx's Avatar
im about do redo the seals in my forks. couple questions.... where do i get seals, i found some for f2s and f3s but not f1s, can i use f2-3 seals? second, do i need any other new parts besides oil and dust sheilds
thanks
Old Feb 23, 2007 | 04:48 AM
you can find them on ebay or honda dealership or any motorcycle shop that sells parts. f2/f3 forks are larger diameter than f1.you need nothing of else if only seals are getting changed.
jaysee
May 18, 2012 06:27 AM
stealthCBR929
Feb 27, 2012 06:37 PM
tareemup
Apr 29, 2009 09:50 AM
ldv12
Apr 14, 2009 08:15 PM
