new 89 f1 owner with wierd problem
Old Apr 8, 2008 | 09:47 AM
jaymag87's Avatar
Default new 89 f1 owner with wierd problem
hey everyone just bought my f1 3 days ago and love it but my problem is that when i am accelerating it starts to bog until i open the throttle up alot more and also it boggs when trying to stay at one speed. any help would be great thank you[/align][/align]
Old Apr 15, 2008 | 04:40 AM
Gearloose's Avatar
Default RE: new 89 f1 owner with wierd problem
There's a whole heap of possibilities - here's an extract from the manualat CBRExtreme.com. If that doesn't work,there's more in the manual.
[IMG]local://upfiles/20544/59030E8586284854970CA6BE80062A93.gif[/IMG]
Old Apr 15, 2008 | 08:47 AM
dalex's Avatar
I have a similar problem as yours and am trying to figure it out. Mine bogs mostly when I try to really open the throttle and does it especially while on the highway at around 70mph. It seems that I'm running too rich and while I have yet to adjust the pilot screws, I believe the real issue may be with the main jets. I may need to go down a size but have yet to find the time and get into it.
Welcome to the forum and gl in finding a solution. Please let us know if you do.
Old Apr 15, 2008 | 11:49 AM
Draggin's Avatar
Yes, please post if you figure it out. I guess now there's 3 of us working on it....lol
Old Apr 20, 2008 | 06:51 PM
87Cane600's Avatar
Make that 4! Mine seems to come and go. Drives me crazy!
Old Apr 21, 2008 | 12:33 AM
thegreenbandit's Avatar
I'm kinda new to motorbikes. But I was thinking it might be your Carbs are out of synchronizing? There is 2 pilot screws on them that you have to adjust for them to work proply with each other. And I've been told theres a sync tool you can buy to help you set them. Otherwise you need a tachometer
Old Apr 23, 2008 | 02:19 PM
jaymag87's Avatar
lol thanks guys havnt been able to work on it recently laid it down badly so in the process of getting new plastics. but i took it to a shop and they said it may be the carbs were not cleaned right. does that seem like a possible solution?
Old Apr 23, 2008 | 03:50 PM
dalex's Avatar
Since I last posted in this thread, I did a number of things that sorted most of my problems out:
- Took the carbs apart and re-cleaned everything carefully
- In the process, discovered I have 102 main jets (will upgrade eventually)
- Covered the brass tubes next to the intake boots as described in this thread
- Re-adjusted the pilot screws
- Put some seafoam in the tank and in the crankcase (not much)
- Covered half of each one of the two intake holes on the frame (to avoid a lean condition at highway speed - my intake holes on the front fairing are 'oversized')
I am amazed at how good she runs now. There's still a VERY slight hesitation around 6-7k rpm in high gears when at WOT but nothing to go crazy about. Otherwise, she revs right up to redline and even scares me in the process . Can't wait to see result once I put larger jets in.
Old Apr 25, 2008 | 10:09 PM
tds94probe's Avatar
did you say 102?????????????? the bike comes factory with 105's.........
94cbr600kid
Dec 19, 2008 09:18 PM
RocketJocky
Jul 10, 2008 11:17 AM
GR8TSCT
Jul 1, 2008 11:34 PM
Iguana954
Mar 12, 2007 11:25 PM
cbrmario
Aug 19, 2006 02:23 AM
