My project is almost done!
Old Nov 9, 2007 | 07:29 PM
SIRGERMAN's Avatar
Default RE: My project is almost done!
did you put any clear on top of the paint ? maybe you can tell me all the steps
[align=left] [/align]
Old Nov 10, 2007 | 12:42 AM
Gogar's Avatar
I would like to put clear on, but I couldn't find one that would work without wrinkling the spray paint i used. I used the little rear piece as a test, and I sanded and painted it maybe 10 times. But in the end, that rustoleum "for plastic" paint worked best with 2 or three really light coats wait 15 minutes between each one, and one thick one at the end. It still orange peels, and I'm thinking of wet sanding it with 400 or 1000 and then buffing it, but I just don't think it's the right kind of paint. Lacquer or enamel would be good, but someone told me they'll crack on the flexible plastic.
And another thing, black is absolutely the hardest color you could ever pick for paint. You could paint it white with frickin house paint and it would look awesome. (but then it would be white, which is gay as hell.) No offense to you white CBR owners out there
In the end I learned a lot about sanding and it's a bitch. Now I understand why someone would want 500 or a thousand bucks or more to paint all 8 pieces of plastic. but it cost me $50 to do the front cowl. both fenders, and the rear cowl and it'll last for a year so whatever.
Old Nov 10, 2007 | 02:56 AM
SIRGERMAN's Avatar
i was going to use http://www.krylon.com/main/product_t...roduct_details
but i dont know , someone need to try and see what happen ,
do you clean the plastic or you have to remove the old paint , and what do you use ?
Old Nov 10, 2007 | 07:24 AM
blaster's Avatar
Old Nov 10, 2007 | 08:37 AM
Gogar's Avatar
ORIGINAL: SIRGERMAN
Well that "someone need to try" is you, buddy.
If it's in good shape, just clean it and wet sand it with some waterproof 400 sandpaper, and clean it off again and spray that $hit.
Old Nov 10, 2007 | 10:58 PM
drakito's Avatar
SEM makes a plastic paint setup, complete with clears and primers to make sure all of it can flex with the plastic. Trick stuff, I use it at work all the time.
Old Nov 11, 2007 | 04:54 PM
grindpunk16's Avatar
can you get more pics of the stablizer. that head would make a nice custom head reshaped bowls newvalves cams(as long as its not cracked)
Old Nov 11, 2007 | 09:23 PM
zorgen's Avatar
Great job. You seem to be quite the perfectionist. The paint really looks great. I wish I had your skills!
suavegav
Apr 15, 2013 04:55 PM
patpatpat
Jan 31, 2011 04:42 PM
axpaj345
Aug 8, 2010 05:15 PM
Cuzy
Mar 7, 2010 05:41 PM
edccbr1000
May 2, 2009 08:24 AM
