Mikuni carbs
RE: Mikuni carbs
you can use f2 swingarm, but
1. the f3 is slightly wider to accomodate 5 inch rim whereas f2 is 4.5 inches.
2. the f3 swingarm/rim combo allows use of up to 180 tire.
3. if you want to use wider tire, go with wider rim and swingarm, this will cause less handling issues.
4. not quite a direct replacement as some geometry issues will need to be addressed.
5. this swingarm stuff is posted elsewhere under a seperate post.
