IMPORTANT - Please read! (pics of crack in frame)
Old Apr 11, 2008 | 03:51 PM
  #21
michigan_313's Avatar
Default RE: pics of crack in frame
ORIGINAL: dalex
ORIGINAL: rrasco
I have yet to check mine. Its been on my list of things to do, but its also on the list of things I just might not want to know.
I shoul've adopted the same attitude...
Damnit! Why did I read this thread? [:@]
I got 'ze crack', and it looks identical to that in the posted image.
It got me thinking and I'm wondering, this is a 20yr old bike, at what age or after how many miles would this crack typically start appearing? If left untouched, does it expand and eventually grow long/large enough to split the frame? Did anyone hear about it breaking off completely? If not, assuming the crack has been there for the past 10 or 15 years, it tells me that this is about as bad as it will ever get and people been riding the bike as is without any other consequence(s). If a repair is absolutely necessary, can it be done with the engine still in the frame?
I'm just throwing out my thoughts on this. I'm pi**ed off that I didn't notice it when the engine was out and don't feel like doing it all over again, especially since it just started being nice enough outside to ride...
the crack can be welded w/ engine in the frame. this should be no problem for an experienced welder. if anything, the engine would act as a jig to keep everything straight. i've got over 90k on my bike and not a crack anywhere. what is causing the crack? undetermined. is it safe to ride with a crack in the spar? maybe. but do you really want to be the one that the frame completely fails on when you ride it? probably not, i'm guessing.
most of the old hurricane/f1's that i've seen were in pretty decent condition or at least taken care of.
mine is an 89. i also have a 88 frame, also no cracks. has anyone noticed if it is happening on a certain year or years?
Old Apr 11, 2008 | 03:54 PM
  #22
dalex's Avatar
From what I understand in this thread and this one, it's always on the left side, in the exact same place
Old Apr 12, 2008 | 10:28 AM
  #23
jmanng's Avatar
Re: why only the left side, I would say that's structurally the weakest point (you're only as strong as the weakest link theory, water always finds it's level... you know what I'm getting at).
In the case of my bike, I believe the bike has been ridden hard in the past (seen the track) as there's some bolts on it that have been drilled so they can be wired to the frame and a few in the headlight bucket that still are. I also agree with an earlier post that wheelie's are also likely culpritas well.
Old Apr 12, 2008 | 01:50 PM
  #24
jmanng's Avatar
Welded (MIG) up the crack just now.I believe I got good penetration and it flowed well (I'm not a professional welder) -we'll see how the weld holds upover time.
Got a slightbit offline following thecrack up asit was hard to follow due to prepping the area (crack got lost in the grind) - so I had to widen theweld. All-in-all, it doesn't look to bad (IMHO). A little bit of dressing up tomorrow and I'll beready to touch it up withpaint.
Jaime
Old Apr 12, 2008 | 02:33 PM
  #25
dalex's Avatar
I know nothing when it comes to welding, will have to have it done somehow. So I should be looking for someone with a MIG welder? How much would it cost (ballpark figure)?
Old Apr 12, 2008 | 02:47 PM
  #26
you can have it either TIG or MIG welded. i prefer TIG, nicer weld, less post weld dressing. but as long as it gets welded it doesn't matter. should cost less than $100.
Old May 6, 2008 | 08:28 PM
  #27
danothedinosaur's Avatar
I just checked and mine has it too. It's probably only on the left side because it's a kick stand issue. This is good news I guess because it means the stresses of riding aren't causing the damage which means regular riding is less likely to make the problem worse.
I need to find someone with an angle grinder and a MIG welder now.
Old May 7, 2008 | 11:27 AM
  #28
That's a good point. Whatever it is, it sucks. I've got the whole thing apart to redo all the plastic and now I've found this. Should be easy to fix I guess.
Old Jul 17, 2008 | 08:19 PM
  #29
thrasher572's Avatar
The bolts were properly tightened... not too loose or too tight. I have welded the second frame with no issues so far.
Old Jul 18, 2008 | 01:56 AM
  #30
Billistic's Avatar
I have an '88 with no crack!
