gears
Old Nov 10, 2006 | 07:52 PM
Karl's Avatar
Default gears
sometimes when i'm riding and i go to change gear my bike feels like it slips in2 neuteral even when i'm in 4th or 5th and then grinds back in2 gear which doesnt sound too healthy. does any one know what this may be and if it is possible to repair? its as if it falls out of gear for a few seconds [&:]
Old Nov 12, 2006 | 12:55 AM
89canemad's Avatar
Default RE: gears
i am srry i cant tell u for sure but sounds like eaither worn out gears or bent shifting forks and yes it would be repairable, but at the same time i have a ? about gearing it is what is the advantages of changeing to a 520 CONVERSION CHAIN SPROCKET?
Thanks and hope i helped any
peace out
Old Nov 12, 2006 | 04:50 AM
gtrude's Avatar
Default RE: gears
Karl....I can't say for sure what it is, but I have the same thing. The bike has done it since I got it, and still does (now at 42K miles). From what I've heard, the transmission's on the F1's are known to do this. I could be wrong, and there may be a fix; but it doesn't seem like anything that ever got worse or caused major damage for me.
greg
Old Nov 12, 2006 | 06:57 PM
michigan_313's Avatar
Default RE: gears
hmmm, here's a few things that could be causing your problem regardless of what gear you are in or what gear the tranny falls into.
1. gear dogs worn or damaged
2. bent shift shaft
3. shift drum stopper worn or sticking
4. worn shift forks
5. broken shift linkage return spring
most of this stuff can happen if the tranny was mistreated.
as for going from a 530 to 520, a 520 chain is narrower and less weight. it allows for better acceleration since the chain and sprocket combo isn't as heavy as a 530 set. a 520 chain cannot be used with 530 sprockets and vice versa.
Old Nov 13, 2006 | 02:32 AM
89canemad's Avatar
Default RE: gears
thanks man so it is a good thing to do cause they r on ebay for 130$ plus shipping but it is like vortex sprockets and XSO chain
wisco
Apr 2, 2013 03:57 PM
Piranha
Dec 16, 2011 05:33 PM
danl23880
Sep 29, 2010 12:47 AM
boost90
Sep 24, 2007 02:46 PM
f4iguy8804
Apr 3, 2007 01:04 PM
