gas tank
would any other models gas tank fit the f1 i want one that can flip up like on hinges but my tank leaks if i tryto do anything like thatdo any other models have this option thanks.
i am doinga rear end conversion and want to make it so the gas tank could flip up as long as i am at it and i think all of theese years leak out of the filler cap but if i cant do it i cant do it right thanks
so they mount just about the same i dont care if the shape is different i am redoing the whole bike i have 2 hurricanes one is gonna be stock and the other to be completly redone new everthing
any cbr tank that you make to flip up will leak because of the way the tank vents. there is the top vent and a bottom vent. the tank will not leak if it is half full or less or depending on how much of an angle the tank is tilted at.
ok i was hoping for like a 45 but if it will leak i will go without it would basicly any model fit if the spacing was good i want the two to look different.
thanks
thanks
f2/f3 tank spacing is going to be close fore and aft. side to side measurement is almost the same.
keep in mind that gas caps are different. so you may need to rekey the cap.
if you want the tank to flip up, make the tank half full and tilt the tank till it starts to leak. that will give you an idea of how far you can flip up. at 45 degrees it should be okay.
SACBR
Jun 19, 2011 11:09 PM
