Gas leaking when engine on.
Old May 12, 2009 | 06:29 PM
Thaibiker85's Avatar
Exclamation Gas leaking when engine on.
A couple of days ago I noticed a smell of gasoline next to my bike while i was letting it warm up. Then i looked down on the left side and I can see a gas leaking down from somewhere. I took a closer look and it's out of a tiny open house up near the carburetor cover. The hose looks like it's supposed to be there. When the bike is off, the rapid dripping stops. Any idea of what and why this is happening??
Old May 13, 2009 | 01:59 AM
tripicana's Avatar
sounds like its leaking out of the float overflow. one or more of your floats are probably sticking or adjusted improperly.
Old May 13, 2009 | 09:23 AM
How can I fix that?? Probably have to open up the carbs right??
Old May 13, 2009 | 11:13 AM
tripicana's Avatar
unfortunately, yes. do you have a manual, or confident on amking the repairs yourself?
when you get to the carbs, leave the metal airbox base attached to the carbs, and pull all four carbs off as one peice. this will minimize any changes to the syncronization. you can pull the float bowls off and inspect the floats. make sure they pivot freely and the needle valve doesn't look worn, or nothing blocking it. check to make sure the level of the float when the valve closes looks the same on all four carbs. the manual says the height of the float should be 8mm from the carb flange, when the little flange just starts to touch the needle.
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
marc0011
Jun 6, 2010 11:55 PM
malbojah
Mar 24, 2008 07:22 PM
markisawesome
Jul 10, 2005 08:11 PM
