fuel leaking from the T's
Old May 9, 2010 | 11:32 PM
Campbell45's Avatar
Default fuel leaking from the T's (now pictures!)
I just bought a 90 cbr600, replaced the head, mounted the carbs, and tried to start. blub blub blub pop! I'm getting backfire from the exhaust and out the carbs. After awhile of trying to start I finally look at my feet and see a bunch of fuel leaking. I look all throughout and see that the fuel is leaking where the fuel goes into the carbs, the fuel rail I think. After further analysis the carbs are not fitting together tight enough and the T's are not setting into the carbs all the way. I can push the carbs together and the leaking stops. But I have no idea of how to tighten them. The only bracket I see holding them all together is up closer to the front ontop of the carbs. So I took the carbs out and started cleaning them I also checked the O-rings and there fine. Any ideas?
Last edited by Campbell45; May 10, 2010 at 09:20 PM. Reason: no one was answering so I put pictures on to try and induce answers lol
Old May 13, 2010 | 11:05 AM
cloaked_chaos's Avatar
Even though your o-rings look fine, they can still have flat spots on them or they could have shrunk. Both of my cbr 600s (87 and 90) have had this problem. Just spend a dollar or two and buy new o-rings. Your problem will go away.
Old May 13, 2010 | 11:07 AM
Shadow's Avatar
New O-rings
Try www.mrcycles.com
Old May 28, 2010 | 06:32 PM
oldschoolCBR's Avatar
Did new o-rings fix your problem?
I hate un-finished threads, hehheh.
Old May 30, 2010 | 01:17 AM
Campbell45's Avatar
Yup I got it fixed I took the carb apart and clamped them together and then retightened them and worked like a charm. I got the bike running strong and can drive it everyday. Thanks for the help everyone!
platnumbob
Jul 5, 2014 09:57 PM
Mulkxican88
Nov 14, 2013 05:23 PM
MegatronousPrime
Apr 29, 2012 09:51 PM
robbiebgraham
Mar 8, 2011 02:47 AM
haak30
Sep 17, 2008 05:24 AM
